UNABLE TO READ DATE FORMAT(DD/MM/YY) FROM EXCEL
Why are you subtracting a half a day?
Message 11 of 23
(3,017 Views)
Its a fudge number. A whole number put the time in the PM close to midnight. To lessen the chance of the date being off a day the 0.5 puts the time in the AM.
Message 12 of 23
(3,002 Views)
Rather than using a fudge number, it would be better to do the actual conversion from Excel date to LabVIEW date.  In this thread, I posted an example which calculates this accurately because the time zone has an effect on the number.  While your fudge factor may work for some people, there would be timezones where it does not work.
Message 13 of 23
(2,988 Views)
The example I gave Does convert from the Excel date (40155) to a format LabVIEW can display (12/8/2009). Your example converts LabVIEW Time to a date for Excel. Unless you manually change the timezone factor in your application which calculates a constant of -.208 the constant always remains the same  as compared to my 0.5 days. 0.5 days was a rough guess to give an example not an exact science.  In this application he is only interested in the date a few hours to account for time zone may not make much difference.
Message 14 of 23
(2,980 Views)
Okay, it was doing the reverse operation.
In that case, you use that example I gave but do the inverse operations to go from Excel date to LV date.
Message 15 of 23
(2,976 Views)
Did any of this help Shruti G?
Tim
GHSP
Message 16 of 23
(2,963 Views)
thanks for the reply....
and sorry for late raply...
i will try this and will get back to you all if still i have problems.......
thank you.......
Message 17 of 23
(2,950 Views)
Thanks Rob_F1!  That worked!  I can't believe all the examples people illustrate, but, yours was the best!  Thanks again for a solution to my Excel WHOLE NUMBER to MM/DD/YYYY problem.  I only wish I saw your post first.  Great Work and Kudos to You!
Doug
Message 18 of 23
(2,361 Views)
Interestingly, this example shows Excel date 1 as 12/31/1899, not 1/1/1900 (at least for me)...
Message 19 of 23
(2,053 Views)
Your time zone differential might be different.
LabVIEW bases time stamps on UTC time.  Excel bases it on your local time zone.
Message 20 of 23
(2,050 Views)
