UNABLE TO CONFIGURE SCB-68
I AM UNABLE TO CONFIGURE SCB-68 THROUGH MESUREMENT AND AUTOMATION. WHEN I TRY TO CONFIGURE I SEE WANTS IN THE ATTACHMENT.WHAT SHOULD I DO?
(2,398 Views)
I think you are confused. The scb 68 is just a breakout board allowing you to wire up the DAQ card easily. It just plays middle man. There is no configuration necessary other than some switches you can set. Are you sure the problem isn't with the DAQ card? Did you restart and try again? Sometimes a simple power cycle or LabVIEW restart clears these things up
(2,390 Views)
