UDS using CAN Diagnostic Frame Recv.vi Error
Hello Experts,
I am using ADCS toolkit for UDS using CAN protocol.
Where I want check service x10(Diagnostics session control), for that ADCS toolkit has 'Diagnostic Service.vi'.
Before that I have configured all input parameter setting using below VI., where I provided Transmit ID as well as Receive ID too.
after that Frame is successfully sent to ECU (I checked in using XNET bus monitor), but I am not getting its (Positive or Negative) response from ECU.
I am getting  -8260 Error code which meaning is 'Automotive Diagnostic Command Set: Diagnostic command timeout. A response from the ECU was not received'.
I changed given timeout but still facing same error.
If anyone knows how to solve this, it will be really helpful to me.
Your help would be much appreciated.
(1,467 Views)
This question is best to be posted on the Automotive and Embedded Networks board
Did you see any response frame from the ECU on the Bus Monitor?
https://tmesystems.net/
(1,439 Views)
