UDP write
Hi
I use a PXIe-8821 CPU in RT. Labview 2016.
I send data using UDP write function. When i disconnect / reconnect the Ethernet cable it seems the UDP write function hangs 1 or 2 seconds. I tried to change the timeout of the UDP write function (i tried differents values without success). It seems this value is not taken into account.
Why does it hangs when i reconnect the cable ?
You will find the example enclosed...
Message 1 of 1
(2,304 Views)
