Hello. We are experiencing an extreme slowdown in communicating with an RT PXI. When the host pc requests data via either FTP or Vi Server, it takes about 90 seconds to transfer 5 MB. We tracked the problem down to an Allen-Bradley device that is broadcasting UDP across the network. When that device is removed from the network, transfer time for 5 MB is reduced to 3 seconds. Note that there are no programs running on the RT PXI and that this problem has been reproduced on other RT PXI systems on the same network. The slowdown is also experienced when using Windows FTP to transfer data from RT PXI. However, there is no slowdown when using FTP between two Windows machines. Does RT PXI always try to process UDP messages? Is
there a way to disable that feature?
Chris White
Archimedes Technology
