UDP Receiver not working without Wireshark
In my LabVIEW application, I have to receive Data frames from a embedded module continuously via Ethernet (UDP protocol is used). My VI receives frames when I start monitoring using wireshark and If I stop monitoring using wireshark, my VI also not receiving data frames. Suggest your solution.
(1,769 Views)
I disabled Firewall also but still same problem
(1,599 Views)
I guess you might have done something wrong.
Bill
CLD
(Mid-Level minion.)
(1,594 Views)
