U32 Read Key.vi with hex value
Is there a way for the Read Key.vi  to read an hexadecimal value when set to U32 (or I32)? (maybe a case for the LabVIEW Exchange Idea?).
It would be cleaner than to read an hex string and then convert it.
Ben64
(2,914 Views)
Write subvi which does it in a way you described it. Seems clean enough for me 😉
(2,895 Views)
That might be one for the idea exchange.  I'm seeing a Decimal String To Number inside of that polymorphic instance.
(2,890 Views)
