Typecast complex to DBL and CDBL
Hello everybody,
I'm trying to figure out how to perform a typcast data formating from complex array data to DBL and DBL to CBDL. This seems quite simple but I couldn't figure it out.
I've attached an example vi.  I don't understand how the dummy variable on the typecast function was created both for the DBL and CBDL constants. When I right click and create constant, I end up with something different. Can somebody explain how to do it.  See attachement.
(2,874 Views)
Right click the constant you created and pick Representation.
I'm not sure what you are trying to do exactly, but you probably don't want typecast.  Typecast is a function to take a value in memory and interpret it as a different type of data.  So typecast a string of two characters to have it become a 16-bit integer.
I'm thinking you might want to use the conversion bullets in the Numeric >> Conversion palette which will actually convert a number to a different datatype without necessarily changing its underlying value.
(2,869 Views)
(2,866 Views)
JonN,
What is the name of the function in the middle and where on the functions pallete can I find it?.
(2,851 Views)
As far as I know, it's not on a pallete...see background here
(2,843 Views)
