Type defs changes not reflected in block-diagram constants?
Just went through a similar exercise here as well.
We were silly enough to change a ring into an enumerated. Only to find that everything then starts with zero.....
So had to revert back, only to NOT see the constants on the diagram update.
Nice surprise.
Makes you wonder what the use of strict typedefs are in this case.
I could really use an enum type were I can define the values for each entry.
As a ring does NOT make code readable (wire it to a case statement, and you only see numbers. Basically useless).
Is this a new feature planned in labview version 9.1?
Message 11 of 13
(663 Views)
You should go kudo the idea for Sparse Enums.
Message 12 of 13
(654 Views)
Done . Gave kudos. Indeed, very good idea.
Let's hope they listen....
Message 13 of 13
(646 Views)
