Type Casting bit array
I store a set of booleans as a bit-array tag to insure that they are not being
updated while a vi makes multiple read tag requests. The booleans start in a
strict type def control, converted to an array, and written to the tag. When I
read the tag I want to be able to apply the same strict type def structuring to
allow use of the unbundle-by-name function. So far the olny way I have been
able to do this is to add the strict type def control to all vi's that read the
tag. The controls are used only as a type reference. Is there a way to prevent
having unused controls? Can type information be accessed without having an
"example" control on the front panel?
Randall Miller
(3,328 Views)
Put the control in a global VI or on the output connector pane of a "do
nothing" VI.
You acces the type with a reference to the global or calling the VI.
Jean-Pierre Drolet
----- Message d'origine -----
De : Randall Miller
Groupes de discussion : comp.lang.labview
Envoyé : 24 mars, 2000 09:28
Objet : Type Casting bit array
being
a
When I
structuring to
been
> able to do
read the
prevent
> Randall Miller
(3,328 Views)
I was out of my mind...
Just put a constant on the diagram that is linked to the strinct typedef....
Use the Select a VI... dialog on the function palette and select your
typedef.
It will create a constant on the diagram that is linked to the typedef
Jean-Pierre Drolet
Jean-Pierre Drolet a écrit dans le message :
38db8767@newsgroups.ni.com...
> nothing" VI.
> Jean-Pierre Drolet
> De : Randall Miller
> > I st
> being
in
> a
> When I
> structuring to
> been
> read the
> prevent
an
> > Randall Miller
(3,328 Views)
