Two labview applications running
I have two applications (*.exe) running in the same time. My main application calls the second application with a command prompt as independent application. At one moment I can see in my main application that the second application is running and I would like to stop it. Is any way to stop the second application from the main one?
(2,477 Views)
Use a shared variable that is common to both applications.  Simple and easy.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(2,476 Views)
