Two different LabVIEW version on the same PC
How is the best way to have two different LabVIEW version on tha same PC
(for example 6.0.2 and 5.1).
Golzio
(3,341 Views)
LabView behaves well with multiple versions installed on one machine. Just install the software using the default paths:
LabView 5.1 will end up in C:\Program Files\National Instruments\LabVIEW
LabView 6.0.2 will end up in C:\Program Files\National Instruments\LabVIEW 6
The Start menu will show the different versions. You can create desktop icons for the different versions also.
(3,341 Views)
Note: By default, when you double-click a VI, it will be opened with the last version of LabVIEW you had open...
Copyright © 2004-2026 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,341 Views)
If you open the VI from LabView (not Windows Explorer), it will (attempt to) open it with the version you are currently using.
(3,341 Views)
