Two DAQ Assistants
Hello
I've got the following problem:
I have a .vi with two DAQ-Assitants. The first one is a DAQ-Input who is collecting the data from several sensors. The second one is a DAQ-Output who should controll a pump.
Now, separately, both of them work fine. The pump works as long as it should and I get all the needed information from the sensors. But as soon as I've got both assistants in the same .vi, the input-one doesn't work... So the pump is still doing their job, while I'm  receiving just the default-values from the sensors... It seems like their waiting for something to finish...
Any ideas what the problem is and how I could solve it?!?
If it helps:
- LabVIEW 8.5
- DAQ USB6210
- .vi is attached
Thanks in advance for any help!
   reepicheep
(3,102 Views)
Oh, I forgot to add that I've got just an Evaluation Software... But I don't think this should make a difference....
(3,094 Views)
The problem might be because both the DAQ assistants will be trying to access the DAQ
simulataneoulsy, try using the same DAQ assistant for both the operations...
(3,085 Views)
I also thought that it could be something like that. But is it possible to use one DAQ-Assistant simultaneously as an input and as an output? And if yes, how?
(3,080 Views)
Althought DAQ Assistants VI's are good to begin with, they are not handy when you want to perform multi-function operations like simultaneous output and input
Unlike what 'lordsatish' has posted, simultaneous input/output is possible in a Multifunction DAQ card ( Analog, digital, counter/timer Multi-function combinations)
There are two things I can suggest you to make your vi work
1. Simplest thing: Put your two DAQ Assistants in separate while loops in the same VI
2. Go to Example VIs shipped with LabVIEW and look at VI's found in Find examples>>Hardware input output>>DAQmx>>synchronization>>Multi Function folder. Here you can pick, modify and use an example VI that suits your application
Anymore doubts, do ask
(3,079 Views)
Thanks for the tip with the two while-loops... works perfectly...
(3,074 Views)
