Two Counter channels in one task ID with DAQmx?
I am writing a program which will control the movement of a gimble on the X and Y axis with servo motors while recieving
position feed back from two encoders on those axis. I am using a 6251M series card's AO to control the movement
of the gimble, while running the encoders into a 6602 for position. When setting up my task ID in MAX I noticed I could add
both ctr0 and ctr1 to the task ID, but  when I tried read the counters with that task I got an error in Labview and with the
test function in MAX  saying I need to use a multichannel read. I can not find a multichannel read under the counter
section of my DAQmx read, and was wondering if this is even possible. I am used to programming with Traditional DAQ
and know you have to keep separate counter task ID's, but having bought an M series card and having to use DAQmx I
was wanting to know if I could combine them.
(2,955 Views)
You can have multiple channels in a single task, but those channels all have to be of the same type.  You can have analog inputs together with other analog inputs, but cannot combine digital inputs/outputs, analog outputs or counter tasks with that analog input task.
Once you pair only like tasks together then you shouldn't run into any more issues like this.
Best of luck,
(2,941 Views)
