Tutorial: Building and Accessing a LabVIEW Web Service Application
I was trying to follow a tutorial about web service application and I meet one problem. I created a simple Labview project I right click Build specification and i didnt find the option Web Service (RESTful) from the shorcut menu as indicated on tutorial. Someone has already worked with this tutorial? I use Labview 2017 with Windows 10
Message 1 of 10
(3,780 Views)
Which Tutorial?  If you want us to try to replicate what you did, you need to provide us more complete information about "what you did".
Message 2 of 10
(3,718 Views)
I was trying to follow this tutorial :
https://zone.ni.com/reference/en-XX/help/371361R-01/lvhowto/build_web_service/
Message 3 of 10
(3,697 Views)
Hi Inverter,
I don't find any reference to "Web Service (RESTful)" in the linked tutorial.
What exactly are you talking about?
Message 4 of 10
(3,691 Views)
I'm sorry , this is the correct link :
http://zone.ni.com/reference/en-XX/help/371361G-01/lvhowto/build_web_service/
Message 5 of 10
(3,684 Views)
Hi Inverter,
the new link is for an old tutorial, aimed at LV2010.
While my LV2011 still shows the possibility to create "WebService (RESTful)" apps, that option is not available for my LV2017 installation.
I guess that option was removed from LabVIEW somewhen in between!
(That old tutorial also mentions MS Silverlight, which also isn't supported anymore…)
Message 6 of 10
(3,680 Views)
Ok, thanks. Some one know some link/tutorial to do practice with WebService with Labview 2017 ?
Message 7 of 10
(3,662 Views)
Hi inverter, what about your first link?
Message 8 of 10
(3,640 Views)
The first link was for old Labview version ( before 10). I would like to find some tutorial for Labview 2017
Message 9 of 10
(3,602 Views)
Hi Inverter,
what's wrong with the tutorial in your own message #3?
(LV2017 even provides the example projects as mentioned in that tutorial!)
Message 10 of 10
(3,596 Views)
