01-13-2006 03:06 PM
01-13-2006 03:18 PM - edited 01-13-2006 03:18 PM
Message Edité par Conseils le 01-13-2006 10:18 PM
Message Edité par Conseils le 01-13-2006 10:19 PM
01-13-2006 03:44 PM
01-13-2006 05:04 PM
01-16-2006 01:31 PM
The DevCon seems to work, but I can not get it to recognize the hardware address beyond the "&" sign. Only the address up to it is used (see sample below). The reason this is important is that my two Ethernet ports are on the same PCI card, therefore the first part of the address is the same (see below). If I include everything in the command I get error messages for DEV_7646, SUBSYS_7646, etc. Do you know of any tricks to get the whole address to be used? If this does not work I will just add another card and it should come up with a different address that I can control.
Sample address:
PCI\VEN_10B7&DEV_7646&SUBSYS_764610B7&REV_30\4&3B1CAF2B&0&70F0
01-16-2006 03:52 PM
01-17-2006 07:31 AM
