Turbocode ?
Does somebody knows how to create a turbocode corect error code?
Thank's
Message 1 of 16
(5,290 Views)
What is a "turbocode corect error code"?
Message 2 of 16
(5,285 Views)
Corrector errore code can be viterbi, reed-salomon, hamming......
In french: "code correcteur d'erreur" 😉
I seek someone knows a turbocode vi.
Ben
Message 3 of 16
(5,275 Views)
Baybe there is a toolkilt to do this in LabVIEW 8.5 (I'm on 7.1 but I can pass on 8.5) ?
Message 4 of 16
(5,242 Views)
"The Complexity of these algorithms and the fact that these algorithms have encumbering software patents are a detractor of implementing these algorithms in a system"
Sorry, I haven't heard of any LabVIEW implementation.
Message 5 of 16
(5,231 Views)
So I will have to code it olone? Smiley Sad
Message 6 of 16
(5,225 Views)
The Wiki page that altenbach provided has at the bottom "External Links". One of these points to an open-source library that can be used in Matlab. I would suggest starting there if you don't get any responses on this board.
Message 7 of 16
(5,198 Views)
Hi ben500fr,
I am sorry but National Instruments doesn't provide such code. You will have to do it by yourself or find it on the web.
Alexandre - NIF
AE
Alexandre M. | Certified LabVIEW Developer
Embedded and Control Systems Engineer (NI France)
Message 8 of 16
(5,168 Views)
Yes, you are on your own. But you will learn SO MUCH MORE that way.Smiley Happy If you have MATLAB and the LV Professional Development system you can use a Turbo Code program written in MATLAB and plug it into LV with the MathScript node. There are Turbo Code examples written in MATLAB on the internet.
PaulG.
Retired
Message 9 of 16
(5,155 Views)
But I don't have a licence for mathlab Smiley Sad
A turbo code isn't very complicated to do, the only thing is to have a soft viterbi.
In LV the coder vterbi is "hard": you give to it a stream of 0 or 1 and it give you a new stream of 0 and 1.
In a soft coder; you give him a stream of number into -127 and 127
-127 is a zero
127 is a one
Question: does somebody has a soft viterbi (or reed-solomon) coder?????
Thank's
Message 10 of 16
(5,142 Views)
