Trying to convert ASCII-Character "â" to its corresponding ASCII-Value with "String To Byte Array" (LabView 5.0)
The result is 226 and that is wrong. In fact it is 131. Is there a bug in this function or did I make a mistake ?
Message 1 of 9
(6,196 Views)
Check out this link. http://www.jimprice.com/jim-asc.htm#extended
About halfway down the page you will find 2 different ascii sets.
Apparently IBM created the first extended ascii set, but Windows changed it.
226 is correct in Windows version.
"Mika" wrote in message
news:506500000008000000DF610000-1031838699000@exchange.ni.com...
Message 2 of 9
(6,195 Views)
Thanks, now I know the problem. But I have to read ASCII-Characters from my equipment that are organized in the IBM way. So how can I get the right value on my Windows based system ? I have no idea ...
Message 3 of 9
(6,195 Views)
I don't think there is a bug with this function. Extended ascii characters are represented by two bytes and they resides in the upper byte (upper 128). String To Byte Array only returns the lower 128.
Message 4 of 9
(6,195 Views)
My earlier response is with respect to keyboard scan codes. I tried the "â" character conversion on LabVIEW 6i, I got the same response. Also 131 doesn't produce "â", but 226 does.
Message 5 of 9
(6,195 Views)
Sorry, that doesn't help me very much ... I think, the problem I have is not clear enough.
My equipment, that sends ASCII-Characters according to the IBM-Standard, wants me to interpret them in LabView which uses the Windows-ASCII-Set. So after the conversion with "String To Byte Array" the value of the sent character "â" is 226. Now the problem: I have to get 131 as value, according to IBM. And I think that's not the only problem, every other character with a higher value than 128 will be translated in a wrong way, too.
All I need is a function that converts my ASCII-Characters sent by my equipment according to the IBM-ASCII-Table and NOT to the Windows-ASCII-Table. If you look it up in IBM-Tables: "â" is 1000 (lower byte) 0011 (upper byte) and
that is (2^0 + 2^1 + 2^7) = 131 and NOT 226. So my functions output must be 131 with an "â"-input.
By the way, 226 is 11100010 and that is "Ô" (IBM-Table).
Message 6 of 9
(6,195 Views)
I can't seem to be able to figure out the simplest way to solve this. The closest I encounter was using mapping i.e mapping one character set to the other.
Message 7 of 9
(6,195 Views)
You could create a lookup table with all the ibm codes in column 1 and the
corresponding windows codes in column 2. Search column 1 for the given
value and then index out the value from column 2.
news:506500000005000000B4AB0000-1031838699000@exchange.ni.com...
problem, every o
(lower byte) 0011 (upper byte) and that is (2^0 + 2^1 + 2^7) = 131 and
Message 8 of 9
(6,195 Views)
Thanks everybody, especially Adam. I tried the lookup table in a similar way and that works perfectly.
Message 9 of 9
(6,195 Views)
