Trying to array physical channels with channel names in DAQmx
         I am trying to setup two arrays that will list whatever active channels have been selected by the user and a corresponding array that list the local name for that strain gage in this instance.  I have attached two screen shots.  Shot 1 is what I want it to look like all the time, and this is what it looks like for the first run, but you stop it and then run a second time, it renames the physical channels to whatever is in the local name.  I want them to stay seperate.  Any thoughts would be helpful.  Thank you.
(3,029 Views)
Hi TatankaWilly,
Is it possible for you to provide screenshots of your VI block diagram so that we could see what is going on in your code to get more of an explanation of why the names are changing the second run?
Tommy G.
Product Manager - Search, My Account, and Chat
(2,990 Views)
Yes, I don't know why I didn't in the OP.  Here you go.
(2,980 Views)
Hi TatankaWilly,
I think the DAQmx Property Node that you will want to use to display the physical channel name is this one:
Tommy G.
(2,944 Views)
