11-29-2011 07:39 AM
I have seen a lot of ex. about transfer function implementation, but i need to implement my TF without using a Control Loop, just a while loop with a "transfer function" function from CDeSimulation.
The point is very simple: just filter a signal with a low pass filter using my own transfer function and take the output signal, in the domain time..
I try to realized a project (if you want to see in the attachement file) but it isn't working, even if i put very simple TF and basic signal. So i wonder if anyone had the same problem or just can see where the problem could be..
Thank You.
11-29-2011 08:38 AM
