Try to distribute a LV2009 with NIDAQmx runtime
Good Morning
I try to make a application builder with Ni DAQmx 8.9.5. The DAQ hardware is optional; some computer will have the DAQ hardware (USB-9211A), some don't have.
But, after making the distribution package, I reboot the computer. At the startup, WinXP dialog box:
Title : nidevmon.exe
Msg: This application can't start because numhwcfu.dll is missing.... (something like that, I use XP in French)
Answer : OK
So, if I try to execute the exe, I need to fin the library "nilvaiu.dll".
With LV2009 distribution kit, I include :
NI LabVIEW Runtime Engine 2009 (Full)
NI Measurement & Automation Explorer 4.6 (Full)
NI-DAQmx 8.9.5 (Full)
Any idea why missing dll?
Thank
Message 1 of 9
(5,096 Views)
CFiset,
Hello! Your issue seems similar to the one in this forum thread, take a look at it to see if it helps you out any. Also, take a look at these following articles on our website.
Error 0xc0000022 at nidevmon.exe
Application Error nidevmon.exe in Traditional DAQ or DAQmx
Ben Sisney
FlexRIO V&V Engineer
Message 2 of 9
(5,061 Views)
Hi Ben,
The fist link is about the issues with "nidevmon.exe", but with LV 7.1, Windows Vista, and don't ask for a missing numhwcfu.dll
The second link is about Error 0xc0000022 at nidevmon.exe on Vista because User Account Control properties
The third link is about a blue screen in XP (I believe)
Basically, I need to distribute a application made with LV 2009, using an optional USB-9211A. So I need to distribute LV Run Time (2009), NI-DAQmx (8.9.5 Full). Then I select the under "Additional installer", I select
So, when I install on a production system, the package install
NI-DAQmx 8.9.5
NI PXI Platform Services 2.4.2
LabVIEW C Interface
I find a fix, but I don't like because I need to distribute the application over 50 PC. If I install my package and after I install NIDAQmx 8.9.5 from the DVD, this will work. But over 50 PC, this will be pain ...
What I can do?
Message 3 of 9
(5,049 Views)
CFiset,
Do you mean to say that in your installer you are including:
  • NI LabVIEW Runtime Engine 2009 (Full)
  • NI Measurement & Automation Explorer 4.6 (Full)
  • NI-DAQmx 8.9.5 (Full)
But what is actually getting installed is:
  • NI-DAQmx 8.9.5
  • NI PXI Platform Services 2.4.2
  • LabVIEW C Interface
Or are you asking how to include DAQmx, PXI Platform Services, C Interface, and MAX with your additional installers?
PXI Platform Services are included with VISA, which is included with MAX. So you've got that included, however, what do you mean when you say "LabVIEW C Interface" do you mean the Code Interface Node or the C interface to LabVIEW FPGA?
Ben Sisney
Message 4 of 9
(5,020 Views)
Yes,
My installer include:
And getting installed is:
  • NI-DAQmx 8.9.5
But, the only think I want with my exe is a working NI-DAQmx 8.9.5 (now, is missing dll)
Has I said before, if after installing my application and after reboot install NI-DAQmx with the DVD, I will get everything working. But doing this 50 times for 50 PC is pain...
Thank
Message Edited by CFiset on 11-19-2009 01:13 PM
Message 5 of 9
(5,017 Views)
CFiset,
Can you post a screenshot of the error message that you are getting? That would be very helpful in troubleshooting this issue. Also, you might try installing the latest version of the DAQmx Drivers. After doing that, rebuild your .exe and installer and see if you are still getting that missing .dll message.
Ben Sisney
Message 6 of 9
(4,989 Views)
After installing my computer, I reboot the PC. I got the message after login.
This application has failed to start because nimhwcfu.dll is not found. Reinstalling the application may fix this problem.
Message 7 of 9
(4,979 Views)
1.4 GB for NIDAQmx 9.0.2 ??? It's big! I will need to ask IT before downloading this.
When I will have it, I will try
Message 8 of 9
(4,977 Views)
Accepted by topic author CFiset
I try with 9.0.2 to remade my application build. Everything work great.
Thank for your help
Message 9 of 9
(4,952 Views)
