Trouble with invoke node
I am having difficulties with one of my Invoke nodes in teh attached file. I am not attaching the vi that it calls on, because I do not think it is needed to solve the problem. I think teh issue lies in Data Type Descriptor. I do not know what kind of input to give it. The data is a string.
I would appreciate any input.
Thank-you!
Ivanka
(2,730 Views)
Hi Ivanka,
you are right with the type description as an error.
I've made three things:
1 I rearranged the block diagram to meet programming style guide and beeing able toread what you have done.
2 I corrected the Set Control Value call
3 I added a Close Reference at the end. If you open a reference you need to close it otherwise you will get a memory leak.
I have attached the changed VI.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,726 Views)
Thank you very much!
Ivanka
(2,714 Views)
