Trouble using global variable for file reference
Hi all,
This code is trivial but illustrates the problem I am having.  I want to open a file with vi A, dynamically open vi B, pass the file reference to vi B, close vi B, then close the fiel with vi A.  vi B is designed to continuously sample data and add it to the file.  Unfortunately I can't implement this solution because it appears that global variables do not work for file references(!).  Thanks!
(3,410 Views)
Additional comment: the attached code fails because of invalide file reference.  If the global variables are removed and the wire is connected directly, the code works fine.
(3,404 Views)
Accepted by topic author j_osh_o
You have a race condition in that picture.  The global variable refnum out could be read at the File write before the File Open has had a chance to write a valid file reference to the other global variable refnum copy.  You should have a wire from the Open to the write directly.  If you want to store it in the global variable as well, then branch it off that direct wire.
(3,401 Views)
