Trouble using Shared Variables over my Network
I'm having problems using shared variables over a network. I have been succesful at this before in another network but for some reason I cannot access the shared variable in the host computer this time. I have binded the shared variable correctly in the client computer to the address over the network of the host computer shared variable. When I try to access the shared variable in the client computer I receive the following error.
Error - 1950679022 ocurred at ni_tagger_lv_Read
Possible reasons(s)
LabVIEW: (Hex 0x8BBB0012) The process was not found or is not responding.
(I'm assuming this message suggest that the variable was not found)
I can and access both computers over the Microsoft Network. However either computer will not connect with the Shared Variable Engine. I have tried by disabling the firewall on both computers and had no success. Please advice. Thank you.
(2,778 Views)
(2,748 Views)
