07-31-2012 01:44 PM
I have been unable to use the elapsed time function's output "time has elapsed" to trigger a subsequent event in the event structure. Is this possible? I have no trouble using the event structure when the triggering event is a boolean control. I have attached my VI. Any suggestions would be much appreciated.
07-31-2012 01:47 PM
Writing to a control does not trigger an event. You can create a property node and write to the Value Signaling property. But the event structure has a timeout case. You could put your code in there and write the number of milliseconds to the blue hourglass in the upper left hand corner of the event structure.
