Trouble in starting Labview 2020
Dear Team
Recently I was able to successfully install Labview 2020 (After many attempts which were showing installation error).
But it looks like still installation is not completed even though I reached to the Installed successfully and reboot PC option
Now, I can see the labview 2020 application icon in my PC but its icon is without labview standard symbol and after clicking on it, there is missing application warning and i can locate labview 2020 manually because its missing.
Also,lot of space (More than 20GB) of my PC's Disk is already occupied so I can see software is installed already
Did anyone face this issue , please suggest.
Thanks in advance,
JN
(1,327 Views)
Attaching screenshots of error.
(1,326 Views)
If you had "many attempts which were showing installation error", you might not have a clean (nor complete) installation.  I also see that you are installing LabVIEW 2020 64-bit -- is there a reason for installing 64-bit, rather than the (probably more stable) 32-bit version?
If I were attempting to "fix" this, I would do the following:
  1. Safely uninstall all National Instruments Software.  There are numerous Forum Posts and ways to find how to do this using a Web Search.  I use Control Panel's Programs and Features, myself.  It takes 2-3 passes to do it right.
  2. Download/install NIPM 2020 and start it.
  3. Install LabVIEW 2020 (I recommend 32-bit unless you know you need the huge memory model).  Try to not install drivers.  Install only needed additional items.  Reboot.
  4. Install needed Modules and Toolkits, preferably one at a time.  No Drivers, few Additionals. Reboot.
  5. Repeat as needed.  Don't worry that LabVIEW "force-installs" some Drivers (why do they do that?).
  6. As a last step, install the additional Drivers you need, few Additionals.
This should work (it usually has for me).
(1,304 Views)
