Triggers
I'm going to connect 3 instruments (3 Anritsu power meters where optical sensors are directly connected) using GPIB and I want to collect data from them simultaneously every wavelength step of the TLS (Tunable Laser Source) during wavelength sweep.
Hope somebody could help me on this....
(2,926 Views)
I think the first step is to get the device's documentation and see how to set up the GPIB communication.
Then the second step if you begin with LabVIEW is to have a look at example VIs (Help > Find example... > and search for GPIB in the second tab)
Hope this helps 😉
Epictetus
Antoine Chalons
(2,919 Views)
