Triggering a camera using LabView
Hey,
I have a device that I'm moving using two servos. I'm controlling the motion using LabView. I want to capture the images of the device using MotionPro X3 high-speed camera (To track the position etc). So I need to synchronize the camera trigger and the motion using LabView. The software that comes with the camera (Motion Pro Studio) has the ability to allow the camera to be triggered using an external source. So I generated an analog signal using labview, and I connected a BNC cable from the analog output on the DAQ board to the camera. The camera needs at least 3V so it gets triggered, so I created a point-slider in labview, to increase the voltage from 0V to at least 3V.  I got this part to work.
So now I'm trying to combine the camera control code with the motion control code. In the motion control VI, when I hit "Run" the device starts to move, but data (Position, forces etc) is only saved when I hit "Save Data". What I want to do is to trigger the camera when I hit "Save Data", and not when I run the program. Is there a way to increase the voltage from 0 to 3V when I hit the "Save Data" switch?
Thanks in advance. I appreciate it if you could help me as soon as possible. This is driving me crazy.
(8,658 Views)
Anyone, please?
(8,624 Views)
Hi FirasOSU
If possible, please post what kind of software you have available to work with and the specific hardware. The information I am posting is assuming you are working with one of our data acquisition boards which work with our NI-DAQmx driver.
There are several ways you can trigger the camera from a DAQ board depending on the model. I would recommend that you refer to the following knowledge base/white paper regarding tips and techniques for triggering with a data acquisition board and NI-DAQmx VIs
https://www.ni.com/en/support/documentation/supplemental/21/ni-daqmx-data-acquisition-triggering-tec...
Here you will find information regarding options for triggering with our data acquisition boards using LabVIEW and sample code you can use to add triggering functionality to your code.
Also depending on your camera ports and if you have access to our vision tools that can be added to LabVIEW (Vision Development Module), then you can use the following example code to trigger your camera acquisition.
https://forums.ni.com/t5/Example-Code/IMAQdx-Continuous-Grab-User-Triggered-Snap/ta-p/3522931
Best of luck with your project!
Luis S
Application Engineer
(8,594 Views)
Hi All ,
 I have a Pulnix 6470 CL camera , I have attached that using a PCI NI1498 card and also installed NIMAQ driver. In NI - MAX, its showing NI-PCI, under that its showing channel 0, with camera name Cohu7700cl.
I dont know how to take images from it and how to control using lab view.
I am also not sure if I still need to download any further IVI driver to run that camera or not.
If anyone could help me in this regard
Thanks and Regards
Ashish
(8,273 Views)
Hi!
You can start by using one of the built in examples. Go to LabVIEW » tools » Find examples and use the "hardware" filter to find examples specific to your PCI card.
Finding Examples for LabVIEW
Daniel C.
(8,252 Views)
Hey, did you figure out a solution, I am stuck at a similar issue currently and could definitely use some help.
(8,007 Views)
ZeUs87,
This is a pretty old thread, so you may get a better response by creating a new one. What problem specifically are you running into?
(7,999 Views)
