Trigger on first attempt
 I'd like some help / advice on my LabView program (attached) please. In the VI, the MyVoltageTask_1 is configured as a voltage signal corresponding to a pressure change inside an enclosed cylinder. The signal is transmitted to the BNC 2110 DAQ board / PCI 6133 DAQ card via a differential pressure transducer.
Ideally, the program should trigger as soon as I let air into the cylinder and start acquiring data, and stop as soon as its done. However, LabView does not trigger when I let the air into the  cylinder on the first attempt, but if I exhaust the air and let it in again a second time, the program triggers and I can see a graph of the pressure trace. Please let me know if there is something I should / could change in the program to have the program trigger on the first attempt. Thanks!
(2,673 Views)
Accepted by topic author sg18
Have you try changing the slope from falling to rising? I would start taking a look at the shipping examples first. Open the NI Example Finder and go to Hardware Input and Output»DAQmx»Analog Measurements»Voltage. Take a look at the example called "Cont Acq&Graph Voltage-Int Clk-Analog Start.vi" I contains the basic structure of what you are trying to achieve.
Alejandro C. | National Instruments
(2,651 Views)
Thanks for your response and suggestion. Yes, I did go through the shipping examples, and after making a few adjustments, the program works fine now.
(2,647 Views)
