Trigger a user defined event
 In my application, there will appear a dialog when an error occurs. I hope when pressing the "OK" button on the dialog can notify the main loop to stop, please advise how todo this.
David
Message 1 of 8
(4,699 Views)
Hi David,
you can place a case structure after your dialog. If the result is "true" then you can generate an User Event.
Mike
Message 2 of 8
(4,687 Views)
Use a dialog button.use a case strucure
Message Edited by muks on 08-11-2009 04:22 PM
Message 3 of 8
(4,686 Views)
My idea as follows:
hope can stop the loop by the user defined event, but this event never be triggered. Please give an advise.
Message 4 of 8
(4,658 Views)
Hi David,
if you ask the user before the user event, then you can simply use a case structure.
To get the event, you have to generate the event. Use the "Generate User Event" function for it. You should create the event in any case. Decide only if you generate it or not. Don't forget to use the "Destroy User Event" function.
Mike
Message 5 of 8
(4,634 Views)
Hello Mike,
As your hint I make such a block diagram:
 But it  cannot find any defined data label I've defined from the event structure's terminal. Please give a support.
David
Message 6 of 8
(4,598 Views)
Hi DavidLee,
see the two possibilities to solve your problem.
Mike
Message 7 of 8
(4,591 Views)
Hi Mike,
That is what I need. Thankyou very much.
David
Message 8 of 8
(4,549 Views)
