Trigger&Gate Express VI. Is it possible to control Dialog Box parameters on the frontal panel?
When you use a Trigger&Gate Express VI the Dialog Box Options permits you to configure the VI. I am asking if it is possible to control Dialog Box parameters with controls on the Frontal Panel. I am especially interested on Start Level Threshold.
(2,555 Views)
open the VI that the trigger and gate is in. Right click on the express VI and select open front panel. Then find the control that you want and edit the connector pane to be able to input the parameter that you want. Attached is a modified version that I came up with for you.
Hope this helps you.
Joe
Joe.
"NOTHING IS EVER EASY"
(2,555 Views)
WONDERFUL!
It is exactly what I need!
Your explanation is what I supposed I had to do. Your example is what I need. Now I am going to try to add in the Front Panel controls for PreSamples and Samples and Trigger Channel. I hope to be able to solve the problem. Actually, I am quite afraid of modifying the Express VI... I am not an expert.
(2,555 Views)
Just be sure to save it as a different name.
Glad to help
Joe
Joe.
(2,555 Views)
