Tricky Problem: How to trigger a function by two keys pressed at the same time?
I want to trigger a further function if the cause of two pressed key is true. For example both "cursers up" and "curser left" are pressed at the same time then I will set a LED on true.
I know how it works with one key, but is it possible with two keys?
Need your help!
Sorry for my worse English - I am a german student 😉
(2,494 Views)
here is my try
Greetings from Germany
Henrik
LV since v3.1
(2,483 Views)
