Tree viewer read from json
Hi All
May I know ? ,  Is there any way to make tree view by read from json file ?
Thank you
BR
Bee
(214 Views)
Hell weerapong,
there is no built-in function in LabVIEW.
Is the structure of the JSON- String known? Can you convert it to LabVIEW- Types via the LabVIEW-Json-VIs (or JKIs VIs)?
Greets, Dave
(186 Views)
Here's a simple routine I made a while ago for viewing JSON file in a LabVIEW tree. Each element's tag is the full path name to the element.
(164 Views)
nice!
once upon a time, i figured out, that firefox does have a very fine out of the box .json viewer if you open such a file in firefox browser directly
since that, i always used that one...
I guess firefox can be loaded via labview's dotrnet node ... and ... nevermind
(130 Views)
Hi All
Thank you for your support.
That's a good start for me.
BR
Bee
(79 Views)
Hi Jacobson
May I have your sample with LV 2019 ?
Thank you.
BR
Bee
(63 Views)
@weerapong wrote:
Hi Jacobson
Thank you.
BR
Bee
I attached a zip of the code in 2019. I'm not used to using the new backsave feature so hopefully I did that right.
(17 Views)
