Tree control character size
I want to change the character size of a tree control.
Does anyone know how ?
Message 1 of 8
(4,156 Views)
Manually, select the tree control the pick the font size in the normal manner.
If you want to use property nodes for the ActiveCell ActiveCell.ActiveColumnNumber then navigate to CellFontSize.
David
Correction: ActiveCell.ActiveColumnNumber is required.
Message Edited by David Crawford on 12-01-2006 08:11 AM
Message 2 of 8
(4,156 Views)
Hi David,
Thank you for your reply.
This property node is not available in LV7 Smiley Surprised  that why I could not find it.
Message 3 of 8
(4,150 Views)
Ah you didn't say what version you are using. Is it the ActiveX or the native labview Lists and Tables version you are using?
David
Message 4 of 8
(4,147 Views)
OK, I can see that the native labview tree control was added at 7.0. Unfortunately I can only go back as far as 7.1. The property nodes exist in that version too.
David
Message 5 of 8
(4,146 Views)
I use the native tree control.
ActiveColNum I can find but still not clear how to change the font size
Message 6 of 8
(4,134 Views)
KC, my mistake. Just rechecked my work. The font size property is NOT there in 7.1 either and makes an appearance in 8.0.
Sorry about that.
David
Message 7 of 8
(4,132 Views)
Hi David,
Glad that we come to the same conclusion Smiley Wink
I will have a better weekend now (I think)  Smiley Tongue
Message 8 of 8
(4,125 Views)
