Tree control: Identifying drop between items
I'm having an issue with the tree control(LabVIEW2019 SP1 f5):
When I set the property that “Allow Dropping Between Items”, I need to find a way to get which item being drop is between the two items, unfortunately I haven't found a solution to this problem at the moment.
I need to know if the item being dropped is on a line or between two lines.
Does anyone know how to solve this problem?
(624 Views)
