Tree Drag & Drop - Drop Over
Hi Experts!
I have a small question.I have a tree control, there are many nodes in it. I have allopwed all Drag and Drop properties, and handle the following events:
- Drag Starting? to check if the selected node is "valid"
Using this event I can filter the items what I want to drag.
The tree D&Drop functionality works fine,
but I want to filter  where do I want to drop the selected node. For the filtering I use Drag Over event - Coords - Point to row Column - Tag , and check the tag is valid so the drop will be in right place.
But, when I insert the Drag Over event, and Accepted - set true, the dropping not executes, nothing changes.
BTW, when I delete this Drag Over event again, the dropping executes well, but I can not filter the place where I want to Insert.
Please Help
+++ In God we believe, in Trance we Trust +++
[Hungary]
(2,993 Views)
See Attachment
[Hungary]
(2,984 Views)
Hi Durnek,
could you post a sample vi of your functionality?
Jiri Keprt
NI EE Czech Republic
CLA, CTA, CLED
(2,950 Views)
