Transpose Data
I the attached VI the data output is:
Labview Automation
06/03/2011:7:44pm
Description
Vcc = 4.6V
Power1: 0.522 dBm
Frequency1: 0.471 MHz
X- Data Y-Data1
10 0.941
20 0.728
30 0.136
40 0.877
50 0.298
Power: 0.935 dBm
Frequency: 0.083MHz
X-Data Y-Data2
10 0.174
20 0.827
30 0.481
40 0.924
50 0.596
Power...
Can you tell me how I can go about manipulating the data to get the data as shown below:
Labview Automation
06/03/2011:7:44pm
Description
Vcc = 4.6V
Power1: 0.522 dBm              Power2: 0.935 dBm                   Power3: ...
Frequency1: 0.471 MHz        Frequency2: 0.083 MHz            Frequency2: ...
X-Data         Y-Data1             Y-Data2                                   Y-Data3...
10               0.941                  0.174
20               0.728                  0.827
30               0.136                  0.481
40               0.877                  0.924
50               0.298                  0.596
hiNi.
(3,388 Views)
Hello hiNI
Thank It looks like you would eventually want to output data (for example) from your X, Y1, Y2 arrays by one element at a time with potentially a tab delimeter after X and Y1 and a carriage return after Y2.  Similar characters could be applied to the above data as well in order to obtain this result.  Please let me know if I can provide any further clarification.  Would you appreciate an example illustrating this?
Thank you very much for choosing National Instruments!
Sincerely,
Greg S.
(3,345 Views)
I would sincerely appreciate an example showing this.
hiNi
(3,319 Views)
The trick is to stop thinking like a text-based programmer, and start thinking like a LabVIEW programmer. You're using local variables that are completely useless, and sequence frames to hide code. You also need to learn to deal with arrays. I was bored, so I rewrote your VI so it's clean and easy to read.
You're welcome. Smiley Wink
(3,307 Views)
