Transpose Array
Hallo,
I have a problem to make 1 row 5 column array to 5 row 1 column array.
For example :
Original Array: [a b c d e]
and i want to make it to :
a
b
c
d
e
Can someone help me ?
Thanks a lot
(3,534 Views)
Transpose 2D Array is on the Array palette.
(3,523 Views)
Try using the transpose 2d array function under the array subpalette. This should help.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,521 Views)
If it is 1D array (vector)form you will have to feed it through another build array before you feed it into the Transpose Array function.
Randall Pursley
(3,506 Views)
Transposition only has a meaning for 2D arrays and it seems to me you have only a 1D array.
Could you explain what you want? Is is just a cosmetic FP issue?
If this is a front panel indicator, you can either expand it sideways or downward, depending how you want to see it? There is no math involved.
Is this for a table indicator? Text indicator?
Do you want to write this to a file in a single column insted of single row?
(3,450 Views)
