Transparent Fill Slide controls?
I use a Numeric Fill Slide in my program to indicate the value of a particular quantity that I can set in a variety of different ways.  It occured to me that it would be pretty nifty if I could actually set the value by clicking on this indicator as well.
Then it occurred to me that, rather than change the Fill Slide to a control and setting its value using a local variable when necessary, I could just make a separate Fill Slide control, make it transparent, and put it on top of the Fill Slide indicator.
Unfortunately, this doesn't work: I can use the Paintbrush tool to change the color of the empty Fill Slide to whatever I want, but if I set it to transparent, any objects underneath the Fill Slide will still not show through.
Is this behavior by design?  Or is it a bug in LabVIEW 8.5?  Or is there some other way to make the Fill Slide transparent that I am not aware of?
(3,014 Views)
The background is just a decoration. To color it transparent, you need to click the right edge of the slide, just outside the resize area. Another option is to customize the control and make it very small.
___________________
Try to take over the world!
(3,005 Views)
Acht!  I hate it when that happens.  How right you are.
Thanks muchly!
(2,992 Views)
