Transmit audio signal using Bluetooth
Hi LV folks.
I am trying to find a way to connect to a Bluetooth module and then send a audio signal, which comes from an external device, to this module.
After searching I found this instrument:
http://www.anritsu.com/en-gb/products-solutions/products/mt8855a.aspx
According to the documentation it has the ability to connect to a Bluetooth device and then transmit an audio signal from an external source to the Bluetooth device.
But it is pretty expensive and I don't need all of it's functions, so I was wondering if anyone has an idea for a cheaper alternative?
Is it possible to receive the signal on a PC-soundcard and then via LV transmit the audio through a Bluetooth connection?
Thanks for listening Smiley Happy
Stephan
(3,426 Views)
Well, LV does have the low-level functions for interacting with a Bluetooth interface. The question is how complex the protoicol would be to make it able to communicate with a speaker or headset.
For what it's worth, I have used a cheapo BT interface to talk to a Wii mote from LV.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,421 Views)
