Transition measurements
I need help with finding the duration or Tr/Tf of my waveform using the transition measurement vi found in the waveform measurements subpalette. The rise time duration is correct but the fall time duration isn't. I've attached my vi.
Original post link is below. My vi is there.
http://forums.ni.com/ni/board/message?board.id=170&message.id=185512
kph
(3,758 Views)
KPH,
Out of respect for all the other posts on the forum and to eliminate duplicate work on the part of those trying to help, please refrain from creating duplicate posts on the same issue. If you have any additional information to add, simply add it to the original post.
To anyone that has found this post: please reply in the original post!
Kind Regards,
E. Sulzer
(3,728 Views)
<<Out of respect for all the other posts on the forum and to eliminate duplicate work on the part of those trying to help, please refrain from creating duplicate posts on the same issue. If you have any additional information to add, simply add it to the original post.
To anyone that has found this post: please reply in the original post!>>
Since, I referred to the original post I don't believe duplicate work or confusion is an issue. The reason for the additional thread is that the attachment "feature" doesn't work properly and confusion resulted in the original thread. You should take this as a note to look into the attachment issue.Smiley Mad
Keep up the great work!Smiley Wink
kph
(3,705 Views)
