Transferring files using Web Services
Hello Roger,
Web Services is similar to TCP/IP methods in that it allows you to communicate with remote computer to transfer information, except that it uses HTTP protocol. Both types of communication would need to pass through corporate firewalls, so I recommend that you consult with your IT department on this subject.
Similarly to TCP/IP methods, a multitude of resources exist about using Web Services in LabVIEW. Some of these are:
Overview of using Web Services in LabVIEW
Specific Information for your application
Examples
Please let me know if this information helps or if you have additional questions. Thanks, and have a great day!
Andrew Brown
Software Engineer
Message 11 of 12
(797 Views)
Hello Roger,
To transfer the file over TCP/IP You can use this UTILITY.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 12 of 12
(763 Views)
