Transfering IO to another computer
I am setting up a backup computer for a station on our line.  I transferred all the files and imported all I could, but my block diagram doesn't match nor does the IO.  Is there an easy way to do this since I have everything I need working on another computer?  Everthing in the front panel seems to be there.
 Thank You
(2,414 Views)
What do you mean by 'IO' and exactly how do the block diagrams not match? What, if any, hardware are you using? Obviously, you need to install (NOT copy) drivers such as DAQmx, etc.
(2,394 Views)
