Trafficlight
Hello I have realized this trafficlight with the purpose to do some practice with labview.
Could this be considered as a State Machines in the way it is thought? It works 3 times doing Green->Yellow+Red-->Red-->Red+Yellow-->Green and so on.
Can you suggest me other implementations?
Thank you
(2,968 Views)
This is no state machine. This is a static sequence which is repeated several times.
The issues with such approach are:
- How do you terminate prematurely as such that the program can shut down gracefully?
- How flexible is the code if you have to change order of execution?
- How readable will the code be if you add 1, 2, .., 10, ...100 new "cases"?
You should use a real state machine. You can find an example in the LV template browser which you open by selecting File >> New.
(NOT New VI!)
hope this helps,
Norbert
PS: Do not use variables.
Norbert
Expert: Geometry
(2,957 Views)
Here some WhitePapers talking about StateMachine Design and giving some examples (Step by step):
https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
http://www.ni.com/white-paper/7595/en/
(2,946 Views)
mmm ok i'll read the two files linked down and i'll try again.
(2,937 Views)
