Traffic Generating using Smartbits
How to make SmartBits 6000C generate Ethernet traffic from LabView?
I have a DLL for SmartBits and I'm able to connect it.
Could someone advise something?
Message 1 of 14
(7,092 Views)
Would this help?
 Passing a Variety of Data Types from DLL to LabVIEW
Andy Chang
Message 2 of 14
(7,081 Views)
There is explanation on how to Control an Instrument. The function HTGetStructure is mainly used there. As far as I understand I have to use similar approach using function HTSetStructure (in order to set up transmit parameters) isn't it?
Message 3 of 14
(7,075 Views)
You will need to review the documentation for the SmartBits dll in order to determine which functions you will need to use.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 14
(7,071 Views)
I used the SmartBits 600 and initially used C wrappers around the call to their dll to match LabVIEW datatypes to the complex Spirent datatypes. Unfortunately, I no longer have that code. But, after a couple of years of using that, Spirent sent me a pretty complete LabVIEW driver that they wrote. I don't know who you would have to contact or whether it would work with the 6000 but it might worth pursuing.
Message 5 of 14
(7,067 Views)
Thank you, Dennis, for your response. I've already made an enquire to Spirent and I'm waiting ...
I decided to go forward and generate traffic using at least two simple SmartBits' functions - HTTransmitMode (to set up transmission mode) and HTRun (to start transmit traffic). As I can see HTTransmitMode works fine. But function HTRun doesn't start traffic running.
I have no idea what to do.  If someone has any ideas or has had similar expirience, please reply.
Message 6 of 14
(7,024 Views)
 I've  managed to run traffic using two dll's functions, mentioned above. It works fine.
Message 7 of 14
(6,989 Views)
We've communicated to a SmartBits 6000 chassis with some success using LV drivers linked to the SmartWindows DLL.
After seeing Dennis's response about a LV driver being available through Spirent I made an inquiry also.  This morning I received a link to an old driver (circa 2002) that's linked to the SmartAPS DLL.  Does that sound like the one they gave you Dennis?
I was hoping it would be more of a general purpose instrument driver, but that's all they said they had.
Message 8 of 14
(6,938 Views)
I just looked at some of Dennis's related posts and it appears that he had a SmartBits 200 chassis, so I think that answers my question.
Message 9 of 14
(6,934 Views)
John,
Did you manage to  connect LabView and SmartWindow somehow? Or you just mean that your DLL have the same functions as SmartWindow?
Message 10 of 14
(6,921 Views)
