Tracking time on each section of code
Hello all,
I am running a loop in real-time, and it seems like the loop is taking a very very long time running something (each loop is clocking in at 12sec, where as it used to run at 10ms). I need to know what it taking so long. How do I find out? Thanks.
(2,574 Views)
Bladhart,
There are a couple of things you can do. If you have the Real Time Execution Trace Toolkit you can see what parts of the VI are running. You can alos benchmark sections of the code. There is a good example built into LabVIEW. Under Find examples>Toolkits and Modules>Real-Time>Benchmarking.
You can also use the VI analizer (if you have it installed) or use the Timing and Performance manager under the tool>profile drop down menu. 🙂 I would recommend the RTETT if possible, You can also do some comparisons of Get Time and date in seconds at various points throughout the code to see how long sections are taking and then dividing and conquring the code.
I hope this helps 🙂
Sam S
(2,545 Views)
