Tools >> Options Page in 8.2
Hi all,
today I installed LabVIEW 8.2. Working for some time, I now suddenly cannot open the Options dialog any more. I tried restarting LabVIEW, but without success. This behaviour appears both when used from an open VI menu, as well as from the start-up dialog.
This does not seem to be known in the forums. Is there anyone out there with similar experience and help? I don't want to reinstall...
Regards
Matthias
(2,987 Views)
Is the menu disabled? What happens when you select it? Does LabVIEW hang, or crash, or doesn't respond at all?
Do you sometimes work with two monitors? I read about similar problems where LabVIEW got confused by this. Perhaps the dialog appears, but isn't visible. I think there's an ini file parameter that specifies some dialog positions. Perhaps it's still somewhere on the other monitor.
Hope it helps,
Wiebe.
"matthias.richwin" <x@no.email> wrote in message news:1158675012030-417658@exchange.ni.com...
Hi all,
Regards
Matthias
(2,969 Views)
the menu is enabled. When I select the Options entry in the Tools Menu, the cursor changes to the hour glass for a second, then back to normal. That's it. No more reaction.
I have only one monitor, and did not fiddle around in any ini file!
Regards
Matthias
(2,950 Views)
Despite what you say about your INI file, I would recommend trying the following:
Close LabVIEW, rename your LabVIEW.ini file in the LabVIEW directory (typically C:\Program Files\National Instruments\LabVIEW 8.2) and launch LabVIEW again.  Does the problem persist?
If so, a file on disk may have become corrupted, in which case a repair or re-install may be the most reasonable solution.  However that's more time consuming than if it's just an issue with the INI file, so I'd try the INI first.
(2,931 Views)
I had issued a support request in the meantime. Renaming / deleting the INI file did not help. Repairing the installation did not help. What helped was a complete uninstall, and fresh install from start. Hope that this does not appear again too soon... NI support had no clue at all.
Regards
Matthias
(2,928 Views)
