To verify a condition
I need to create a VI that allows me to determine whether the set point value set by me has been reached by the instrument. I was thinking of a VI that constantly compares the set point and the actual value, and outputs the actual value only after it has been equal to the set point for more than 30 seconds.
(713 Views)
(This is a simple programming questions and does not belong in the "signal conditioning" forum. I have moved it to the right place)
Your "thinking" is somewhat reasonable and that should be easy to implement. What have you tried?
Of course some statements are a bit vague.
  • You need to define what "continuously really means.
  • You need to define what "reached" means, Especially in the presence of noise the tern "equal" is dangerous. Is the setpoint a small valid range?
  • You need to define what "outputs the actual value" means. Output to where?
  • etc.
(708 Views)
Sounds like a simple state-machine
1. Set value
2. Read value
3. If in range start/add to a timer else reset timer
4. If timer is 30, exit and return Value
5. Timeout?
Qestit Systems
Certified-LabVIEW-Developer
(673 Views)
