To store ASCII into Binary
I just want to store a large set of numbers.when i did it..the file is too big to open.is about 100 MB.
its in ASCII ,now i have to convert it into binary files..can anyone help me.
(3,115 Views)
There are many ways to do this. Here is a method that I use.
(3,105 Views)
thx..but my version is 6.1..i cannot open
(3,099 Views)
Show us your VI (or a simplified version with much smaller data) where you currently write the file in ASCII.
Is the file structured in some way (header+data) or are all numbers of equal type and in one big array?
(3,092 Views)
Sorry about that. I can't save this one to version 6.1, so here is a picture.
(3,085 Views)
Well, if it is now too large to open you cannot convert the existing ASCII file ;), instead you should modify your application to write a new one in binary. Presumably, later you also need to have a way to read the binary file back into another LabVIEW application.
Open the example finder in LabVIEW 6.1 and look at the following two examples:
  • Write Binary File.vi
  • Read Binary File.vi
    They are both in section "Fundamentals ... File Input and Output". Let us know of you get stuck :).
  • 0 Kudos
    (3,076 Views)
