To read specific row data from the excel file and writing it to table
Problem statement:I have an excel sheet,in the first column i have serial numbers 1,2,3,4.....and so on.In the input field-if i search with any of the serial number 1,2,3,4... i should get the respective row data as a output.Output as a table format.
Do anyone has any idea how to do it?please give me suggestions
(1,760 Views)
Hi Sahan,
Get the worksheet data as an array to LabVIEW.
Index the first column, search for your serial number.
The result of the Array1DSearch function is the row number: use it to IndexArray the corresponding row data from your array.
What have you tried?
What are the problems?
Where are you stuck?
(1,741 Views)
